Replacing brake line
Malcolm Leick
Bamford (The Peak District) , England
I'm just about to replace the upper section of my front brake line on the 650GS twin with a longer version, so that I can fit a Rox Speed FX pivoting riser and Fat bars.
Has anyone got experience of fitting new brake lines? I'm assuming that I should drain the whole line and reservoir first, replace the upper section, refill the system and bleed through to get rid of any air?
Any advice would be gratefully received!
got it in one
make sure you replace all the copper washers :comfort
if the brakes after bleeding r poo
put a cable tie on lever and leave over night and re bleed
job done
take your time and take it easy just like mark :augie
