I've got a 2011 F800GS which I've had for just over a year it's done about 16k miles. It's got the stalling and rough idle when warm problem that many other people have. BMW did fix it just before Christmas by replacing the idle valve actuator, but it came back a couple of months ago and the bike isn't under warranty anymore.
I've replaced the plugs and the fuel pump (just the pump, not the whole assembly), tried a different idle valve actuator, checked that the breather hoses are routed correctly and not pinched or kinked. I have an Accelerator Module fitted. GS-911 only registers an intermittent short on the heated grips, but no other faults. The problem manifests itself on every ride.
I currently suspect the TPS because if I turn the bike off, then back on and do a TPS reset it idles okay again. Of course, it could just be that something else is going on whilst I'm doing the reset. It idles
badly/stalls even when the heated grips aren't complaining of the short, so I don't think that's a problem.
When I replaced the TPS on an old R1100, there was much faffing around checking voltages, but I can't find similar instructions for this bike. Does anyone know if it's just a plug-N-play change?
It could also be the coils, but I'm not convinced I can check them properly myself.
Cheers.
badly/stalls even when the heated grips aren't complaining of the short, so I don't think that's a problem.When I replaced the TPS on an old R1100, there was much faffing around checking voltages, but I can't find similar instructions for this bike. Does anyone know if it's just a plug-N-play change?
Cheers.
