Looks like I may have the infamous Valeo starter affliction. Pressed the starter button on my 91 100GSPD when I finished work on Thursday just a CLICK, second try on the starter CLICK...... third time started fine, at home put the battery on charge. Friday morning 6.40am started no problem went to work, leaving work Friday afternoon CLICK, each prod on the start button, bol (Dave) of this site gave me a bump start, thanks Dave. At home stripped tank etc off and tested voltage on the switched side of the solenoid when it was pulled in, nothing, but have 12v from battery direct onto the other solenoid contact. Stripped out starter motor and solenoid to check the solenoid contacts only to find its impossible to get at them so guess I need to drill the rivets out to remove the armature and check the magnets in case they are inhibiting the travel of the armature and solenoid. Anyway as I have a spare Bosch start and solenoid for my 78 80/7 I wondered if there are any drawbacks to fitting this in place of the Valeo one to keep the gs on the road.
Have checked out starter motor overhaul here http://www.ukgser.com/forums/showthread.php?t=210783 and here http://www.ukgser.com/forums/showthread.php?t=206156
