Share your tips and experience with us.
Here's a thread on painting:
http://www.ukgser.com/forums/showthread.php?284842
Restoring plastic:
<iframe width="420" height="315" src="//www.youtube.com/embed/6IiRuthCsgY" frameborder="0" allowfullscreen></iframe>
If the plastic is scuffed, before the heat gun treatment you can sand it with fine grade paper.
Another of mine is that De-icer is a good and cheap alternative to penetrating fluids. Buy it in the spring when stockists are off-loading it cheap. It works because the viscosity of the alcohol (or ethanol, whatever it is) allows it to flow into what gaps exist, it also evaporates rapidly and that helps to break or loosen the corrosion.
Restoring plastic:
