Rev limiter 07 GS?
Santa-2512
Omnipotent one
North Pole
Does the GS have a rev limiter and if so at what rpm does it kick in
Only reason i ask, i was giving it some legs on the way home, and in 2nd it hit 6k and just
stopped, almost like hitting a wall. cogged up to third and carried on but backed off before 6k
and all was ok ...
Found a quiet bit of road and tried again it does rev past 6k in third,
I know according to the RPM gauge red line is 8-9K so i naturally assumed it was accross all gears.
If there is a limiter in place in the lower gears, can it be adjusted using a GS911?
Rev limit on a 07 should be 7750rpm (I think) it should rev up to that in the lower gears......... fairly easily.
Sent from a OnePlusX.
Hard revving mine is no benefit and feels brutal. So I don’t do it. As you say the rev limiter is like hitting a wall so another reason to not bother.
If i want to make it go, short (ish) shifting up to 3rd. then give it the full beans does the trick.
Mine flies when i rev it out. Does it good now and then :)
Mine is just under 8k, only hit the limiter in 2nd a few times on local M27 sliproad. Best avoided for mechanical sympathy.
