And the above listed are 50 Ohm connectors, correct for 50 Ohm RG58u cable. (The centre pins are a different size in 75 Ohm connectors as typically used for video)
if you look the one you have,it is an adaptor, i need a plug like the picture, well i did anyways,i found an old one, i chopped offf the coax, removed said coax, used a drift to make the crimp bit round again,cut coax to suit, and re-crimped the round bit hexagon again.
sorted..
Its a £2 plug but most places wanted £6 p and p .dont think so..
