Sold Roadlok
Icky
Member
Penzance
F/S Roadlox used but in very good condition, comes with two keys and key tag to order more keys. This will fit a variety of bikes with the correct spacers and bolt length.
This came off my R1250GSA but should fit others in the range that use the same caliper, please check out Roadloks website for fitment👍
£160 posted UK
Paypal FandF please.
Hi, I bought this new from Roadloks and only received the two bolts but there are extra spacers (different sizes)
For the BMW’s apparently they only send 2 bolts and different spacers. That’s all I got too.
I have had two Roadloks both of which came with two replacement caliper bolts of the right length plus a selection of spacers to line the lock pin up with one of the disc holes.
AFAIK there are no alternative bolts supplied, you just need to get the right kit for the bike - but that kit will fit other bikes as long as the bolt length and caliper spacing is the same. There's nothing to stop you buying different length bolts of course but caliper spacing is the crucial thing (100mm v 108mm). I had one on a Ducati Multistrada before then using it on a Guzzi v85tt - Brembo calipers on both (100mm spacing) and the same length bolts so no issues transferring it across.
See https://roadlokuk.co.uk/which-roadlok-fits
The lock mechanism can be a little fiddly and requires the occassional bit of GT85/graphite to maintain it in good working order. And avoid parking the bike facing downhill with the lock pin engaged (makes it very difficult to remove the pin).
Effective bits of kit (I speak from experience)
Would it be possible to say which model this is. Looking at the website there are different variations, even for a 1250 GSA. I can't read the detail from the photo.
Hi there, It was for my 2023 R1250GSA, centre to centre caliper holes are 100mm, bolt lengths are are 90mm (not including head) and the spacers are around 16mm.
Hope this helps?👍
