Interestingly, I am also looking at replacing the rear shock on my R80ST.
Doesn't seem to ride to badly, but when pushing it off the centre stand or manouvering about the rear seems very 'soft'.
I expect that when I fit a new shock, I'll then realise that the handling was really carp.
So, potentials:
1. Standard fare from Mbins, Mworks, James Sherlock.
2. The Niton offering looks interesting. Will request a quote.
3. Ohlins? Pricey at £600 odd +VAT
Called into FTR Suspension in Bury St Edmunds today. Ohlins supplier. In the catalogue the ST was not actually listed but the 80 G/S was listed. Eye to eye centres quoted as 361mm.
Anybody - Is this the same dimension as the shock for the 80ST?
Also, looking at the shock as currently fitted, (probably the original BMW shock, or a Mbins part), the tyre seems very close to the spring. Did not measure but will do.
I rebuilt the wheels a while back. Did I get the hub/rim offset incorrect?
Anybody - What is the hub/rim offset, measured from the machined brake lining face?
