Rust Removal
BillN
uk
Evening
I want to treat the INSIDE of an old Bicycle frame with rust removal stuff - ideally pour it in and swish it about etc.,
Any recommendations - (stuff to treat inside of petrol tanks)
or do I just use WD40 and treat it every year?
what do you guys think
I find 'Evaporust' quite good. Around £35.00 for 5 litres on e-bay.
I soaked a couple of large lathe chucks in the stuff in a 40-gallon drum (15 litres in the bottom - not 40 galls ;)) they came out all shiny (big, 16" dia jobs for my Colchester Triumph). I also use it for smaller items. It becomes less effective with use as the active ingredients get used up, meaning a longer soak.
If you wipe the item clean rather than wash it off it provides a protective coating.
I believe 'POR Metal Prep' is similar.
Bob.
Plug the holes up and put in some diluted phosphoric acid, leave it for a fortnight then drain it out.
DOnt forget about it like I did though,
One R80G/s swingarm mostly dissolved,
I would fill with evaporate, leave a couple of days then wash it out, dry and then something like acf50, pour a load in and continually turn the bike until everything’s covered.
