My Super Tenere ECU arrived today from Off-The-Road.de in Germany. Sent on Monday morning, back on Friday morning. Turnaround time at Off-The-Toad was under 2.5 hours before it was on its way back to me again. I reckon they should do a "next day" return courier option which might cost more but I'd have been happy to pay for it as it would result in a 3-day turnaround.
Blurb here including a power graph.
First things first - the ECU came back in my original packaging, plus a sticker on the ECU itself which I have removed, some leaflets and a small pack of chewy sweets. Yum. No holes drilled in the ECU or anything like that - it looked just the same as I sent it.
Installation was a 15 min job - just the reverse of the instructions they give on their site here: http://www.off-the-road.de/out/media/Ausbau_ECU_XT1200_final(1).pdf
Obviously I had to reset the clock as I'd disconnected the battery before removing the unit.
Would it start? Yes it would. Whoop. I decided to go for a ride and use T-mode initially and then S-mode after I'd made sure T-mode was good.
The first obvious and hugely appreciated improvement is the pickup when pulling away from stationary. It is now much much smoother than before. That really annoying "stumble" you get as you pull away is now eradicated. Awesome. It really annoyed me and even the tweak of "that screw" didn't get rid of it. Now the bike is as smooth in that off/on throttle situation as my old carb'd KTM 950SM, and that was beautifully fueled. No more excessive clutch slip to get a smooth & fast pull away. So in T-mode there is a very definite improvement to throttle pickup which is almost worth the re-flash alone! Other than that, T-mode remains pretty much as before.
Now on to S-mode. OK, so I want to avoid hype here, but the bike is now just amazing. Pickup and pull is significantly improved. Acceleration is now very strong in the 1st 3 gears. Roll-on acceleration (e.g. for an overtake) is much improved. It is notable just how smooth the engine as it revs through from nothing to the red line. Again, in comparison to my KTM 950SM which I sold to get the S10, the S10 now feels nearly (but not quite) as responsive as the KTM. For a big dual-sport bike that is quite something. I did miss the "zap" of the KTM when I sold it, but now I've got comfort, wind protection, long range and a super-brilliant engine.
Previously I hadn't really noticed the crippled that much power as there's nothing really to compare it to. It just felt a bit "weird" when opening it up in the lower gears - somehow a bit disconnected from your throttle hand. However, now the bike feels simply "right". It's not "an animal" or "obscene" or "gut wrenching". It's just simply superb. Seasoned riders who are mechanically orientated will know how an engine should feel. It is a bit like when you've been riding with a passenger for a long tour, and then you get home and they get off, and you take the bike out and it feels lithe, responsive and agile. It's as though a veil of sludge (can you have a veil of sludge?) has been washed off with jet-wash.
Needless to say I am impressed. I am amazed Yamaha crippled the bike in the way they did if this is what it was like to begin with. Their engineers must be weeping in a corner somewhere.
Note that the bike remembers what mode you were in when you switch it off, so if you were in S-mode, when you turn the bike on again it's still in S-mode.
Summary: highly recommended.
