Screen Just Went Blank
BBB61
Welwyn Garden City
The screen on my laptop just went totally blank. I connected it up to the monitor on my desktop PC to see if it would work via that, but it didn't pass on a signal to the desktop monitor. Any ideas what the problem could be? The laptop has integrated graphics so no seperate graphics card. I suspect it is something to do with the graphics element of the motherboard. The laptop is a 6 year old Acer Aspire.
If you dont actually get ANYTHING at all displayed when booting, I have a nasty feeling it's hardware related rather that buggered software drivers, but if you get the normal start up lines when booting, you may be able to load some drivers and take it from there.
try hitting f12, or whatever key normally takes you into setup when the laptop is booting, if you do get anything on screen at all....
PS a quick google came up with this which looks remarkable similar to your problem
Hello,
Before doing any of that bios upgrade mem stick stuff try the following. It's easy.
- Turn your laptop over.
- Remove the rear access panel.
- Inside you have; graphics card, fan, heatsinc etc, system ram: but most importantly, two installed cards that are about the same size. [Also maybe a small modem thing somewhere but forget that.]
One is the wireless lan card (Intel 4965).
The second is the Intel (turbo) memory controller: it has some drive application aswell, but forget that for now.
[These two cards I believe are on 'PCI' slots]
Remove the Intel memory controller card: it's not clearly marked but easy enough to decide it's not the wireless card. {No wires attached that are lead off to antennas}.
Turn your laptop back over - be carefull because you may not have replaced the rear cover. Press the power button to start the laptop. Does it work?
I hope so. Once your system is running you may try replacing the Intel card, and reinstalling the drivers 'if you need to'. It will probably all work fine.
P.S. Pure speculation but, did you by any chance try installing unidentical memory modules. The 5920 is dual channel symetrical, so maybe it upsets the memory controller. If so, I'm just guessing; I havn't googled for any insight on this.
I did however google the Intel memory controller to understand a bit about what it does. It appears unessential for a fully functioning laptop. Therefor if Intel mem controller is faulty, your still ok, It's got something to do with Readyboost and Readydrive.
2) also this:
<iframe width="960" height="720" src="http://www.youtube.com/embed/iHkGkw9EE8c" frameborder="0" allowfullscreen></iframe>
Hello Bill,
The screen went completely blank on me while I was using it so I suspect it is hardware related. When I boot it up now there is just a blank screen. Everything else seems to be working.
I tried the thing suggested for the Aspire 5920 but I couldn't find a turbo memory card, just the wireless card.
