seal dimentions R100GS 1990
bernardofeio
Portugal
Hello
I need the dimensions (or the reference) of the seal of the output bevel “shaft” the for an 1990 R100 gs
Can anyone help me?
thks
hello
dimensions 85*110*10
18€ + VAT! (@BMW)
BTW: does any know if it's possible to change the seal without disassembling the bevel?
hello
Yes, it's possible. You only have to remove the wheel and brakes.
It's smart to take a visual inspection of the bearing when you have removed the old seal.
Try a search on ADV Riders Old School forum- there is a recent thread on rebuilding a bevel.
From memory the end cover just unbolts, but there are shims underneath to preload the bevel bearing, so it is probably wise to have these to hand too, in case the adjustment needs redone.
You don't have to remove the cover, bearing or shims. It's a 30 minute job.
