The
Almax are the best chains out there! They are the nuts, unlike the others which make claims that are just bollocks frankly. Used in combination with a Hardie Ground Anchor and a Squire Lock your bike is virtually theft proof! The scumbag(s) will need power tools to get through this bad boy!
Almax Series III has never been bolt cropped by ANYONE EVER!
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/-bZMvrPo34g?fs=1&hl=en_GB&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-bZMvrPo34g?fs=1&hl=en_GB&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Unlike the other big name chains that are cropped in seconds - literally!
(Abus City X-Plus, Abus Granite, Oxford Monster, Datatool Python, English Superlink, Squire MC4/6 and Kryptonite Fahgettaboutit)
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Cpf35C7wu6Q?fs=1&hl=en_GB&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Cpf35C7wu6Q?fs=1&hl=en_GB&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
They come in various lengths, which will obviously affect weight. The Series III Weighs 4.34kgs (9&1/2 lbs) per metre
0.7m (2'3") 3.04kgs (6.6lbs)
1.5m (4'11") 6.51kgs (14.3lbs)
2.0m (6'6") 8.68kgs (19.0lbs)
2.5m (8'2") 10.85kgs (23.8lbs)
Diameter of each link 16mm (0' 6/10ths")
Inside measurement of each link 100mm (0'3 9/10ths")
Outside Measurement of each link 132mm (0'5 2/10ths")
Outside Width of each link 56mm (0'2 3/10ths")
Aperture needed for the chain to pass through 58mm (0'2 2/10ths")
The chains have a long 16mm diameter link design with a square profile. Best used with a closed shackle.
The only 16mm quadruple tempered security chain, Case hardened (not through hardened), Carbon manganese alloy steel enhanced with boron, Thatcham approved Cat 3, Impervious to hand bolt cropper attacks, Hacksaws useless, Zinc plated with gold passivation for maximum corrosion protection, Almax's long link system allows you to lock your chain off tight, stopping sledge, wedge and freeze attacks dead in their tracks.
Uniquely designed and engineered to deter even the most foolhardy thief. Virtually indestructible British design. DIY instructions allows easy fitting within minutes. Comes complete with all fixing required including the drill bit!
Carries Europe's highest security Rating of CEN6, Boron alloy hardened steel 13mm diameter closed shackle – Solid hardened steel body, 65mm wide – 6 pin tumbler lock mechanism – double locking – Anti-drill module. This lock is manufactured in Britian from 32mm thick solid hardened steel giving maximum protection from sledgehammering, drilling, sawing and other forms of attack. The closed shackle design provides TOTAL protection against boltcroppers. – 10 year guarantee – Sold Secure GOLD
I have the Immobilser III chain, Squire SS65CS Stonghold Lock and the Hardie Ground Anchor as outlined above. I have ZERO buyer remorse and cannot reccomned them highly enough. I even got a small Kriega bag thrown for free, which that attaches to the seat and holds my chain and lock when I do take it out.
Cost for the package £210-240 depending on chain length. This is the ONLY physical security you'll need... Here's a video of a lorry hanging by the Hardie Ground Anchor!
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/JN99NGYD7Ac?fs=1&hl=en_GB&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/JN99NGYD7Ac?fs=1&hl=en_GB&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Don't waste good money on shite, get the best. These are cheaper then the big name brands which pale into insignificance compared to Almax!
xXx
