Sending a gpx file to Zumo xt via Drive app
Berin
South Oxfordshire
Sigh.
I haven't done this for ages, and now it's either broken or I've forgotten.
To transfer a GPX file from my iPhone, I'm pretty sure this is the method I used to follow;
1) Locate the file on the iPhone.
2) Share button
3) Select Drive app
4) Send file
However, when I do this now, Drive doesn't appear as an option (although the stupid Explore app does)
What's going wrong?
Try deleting the Explore and Drive apps.
Then reload the Drive app.
Which phone are you using?
It's an iPhone 15. I've already un-paired the Zumo and the phone, deleted and reinstalled the Drive app, re-paired the phone
I can send a location to the Zumo from Drive, by entering an address or postcode in Drive app, so the phone is talking to the device
From iOS Share menu have you selected the "more" option?
Drive should be there at the bottom of the list.
It sort of "guesses" what apps are compatible with the file type.
But you can force certain apps to be displayed in the share sheet.
I’ve figured it out, it’s along the lines our esteemed Roman correspondent mentioned.
Basically, if you just locate the file in file manager then press Share the Drive app doesn’t appear.
However, if you locate the file, click it to open it (and then end up with a page of gobbledegook text) and then >share the the phone looks for apps that can open the file and the then drive app appears as a destination
If you are using an Android phone it will put unused App's into deep sleep.
Sometimes open, play around with an APP then close it, and it will reappear in your list of options
