Sharp Helmet ratings
Look at it in detail,
eg:
test date - 12/6/08.
weight 0 kgs
when they actually put some facts up it might be useful, as there is no way a £70 RST is better than my Arai.
eg:
weight 0 kgs
Well it looks like the details for each helmet need filling in, these results have just been published.
But, well, it looks like the £70 RST is better than your Arai.
There will be screeds of stuff arguing the toss but meanwhile I like this:-
QUOTE
How good is your helmet? Will it actually protect your brain in your next crash?
These seem like easy questions, ones you probably think you can answer by reciting the lofty standards your helmet meets and the lofty price you might have paid for it. But the real answers, as you are about to see, are anything but easy.
There's a fundamental debate raging in the motorcycle helmet industry. In a fiberglass-reinforced, expanded-polystyrene nutshell, it's a debate about how strong and how stiff a helmet should be to provide the best possible protection.
Why the debate? Because if a helmet is too stiff it can be less able to prevent brain injury in the kinds of crashes you're most likely to have. And if it's too soft, it might not protect you in a violent, high-energy crash. What's just right? Well, that's why it's called a debate. If you knew what your head was going to hit and how hard, you could choose the perfect helmet for that crash. But crashes are accidents. So you have to guess.
To understand how a helmet protects—or doesn't protect—your brain, it helps to appreciate just how fragile that organ actually is. The consistency of the human brain is like warm Jello. It's so gooey that when pathologists remove a brain from a cadaver, they have to use a kind of cheesecloth hammock to hold it together as it comes out of the skull.
Your brain basically floats inside your skull, within a bath of cervical-spinal fluid and a protective cocoon called the dura. But when your skull stops suddenly—as it does when it hits something hard—the brain keeps going, as Sir Isaac Newton predicted. Then it has its own collision with the inside of the skull. If that collision is too severe, the brain can sustain any number of injuries, from shearing of the brain tissue to bleeding in the brain, or between the brain and the dura, or between the dura and the skull. And after your brain is injured, even more damage can occur. When the brain is bashed or injured internally, bleeding and inflammation make it swell. When your brain swells inside the skull, there's no place for that extra volume to go. So it presses harder against the inside of the skull and tries to squeeze through any opening, bulging out of your eye sockets and oozing down the base of the skull. As it squeezes, more damage is done to some very vital regions.
None of this is good.
UNQUOTE
The article continues here http://www.motorcyclistonline.com/gearbox/motorcycle_helmet_review/index.html and is well worth a read, it's very informative.
SHARP is supposed to be promoting safety awareness and improving the the impact resistant qualities and therefore trying to reduce head injuries when wearing a helmet. It is also trying to ensure that people understand helmet fit too. This is A GOOD THING!
It doesn't matter if your £450 MotoGP/WSB/BSB lookalike helmet is exquisitely painted and laquered to an inch of it's life, if it doesn't fit correctly and do it's job properly, it ain't worth a w*nk!!!!
For the record, I wanted a Shoei, but it didn't fit my head. I liked the HJC Carbon, but that didn't fit my head either. I own a ROOF RO10 and an ARAI Viper GT. both fit me well, with the ROOF being quieter and giving better comfort, (as does a Schubert for that matter).
Fashion and snobbery are all too prevalent in the British biking scene. Why can't we welcome a positive approach to safety?
Here is a link for the test protocols.
