ELIMINATOR
OK I've had this a few years now. In the past I stuck some vinyl on the petrol tank to stop the paintwork getting damaged. I used to fold over the lead edge of the bag, so that the nylon outer was up against the tank, hence the vinyl.
I loop the front restraint between the headstock & the ignition switch.
The lower straps are looped over the plastic cylinders that go from the airbox to the throttle bodies.
This time, I have fitted it the same way, except that I have not folded the shite bag, and the soft lining is on the petrol tank.
I was pondering putting the lower straps on the cylinder head side of the throttle bodies, not quite sure if it will foul against the L/H cylinder throttle cable assembly though.
Question is, how do you fit yours?
