ok removed header pipes for polishing as they were a disgrace, as usual rang the heads off the four studs holding the pipe on
any way got about 10 mm 0n each still left
have ordered four new ones , lashed plenty a WD on the past few nights, trying my best to avoid drilling
anyone got any ideas out of the usuall, thanks in advance
A hoor of a Job , My heart sinks every time it happens ,,, A Balls.
Usually i jump up and down , Fuckin and Blindin .
I spent several Hours on two bolts recently , and you can learn from my
mistakes ,,,,,,, Everyone says ,, Drill it ......
My advice is THIS IS THE VERY LAST THING TO TRY , its inevitable you
will go off center ,and fuck what ever the Surface is mated to.
Tke it to an engineering works before this
Theres a good few ways of doing this . Heat ..
Heat , have you access to a blowtorch , doesnt have to be one of the big ones , a wee gas cylinder type will do the Trick ..
Heat up the Bolt , let it penetrate , cup a tea , then heat it again ,
Then
If you have any imperial sockets , if you can get one ,to nearly but not quite fit , then hammer it on and gently gently .
Get an edge on one of the Flats of the Nut , and try with a Flat screwdriver beating with a hammer to loosen it
If your anywhere near an engineering works get them to weld something
high tensile to the Nut and work it off , If its not high tensile dont bother.
They will know what your talking about
to beat it around.
Bet you wish you never started ..
The Big one here is to take your time , and its gonnie take time ,
probably frustration ,,,
Heat , take a Break , Heat , then take your choice
