oilcan
Having recently fitted a Wilbers rear shock which was 10mm longer than the standard shock to my 1100, I have noticed the lean angle of the bike when on the side stand is considerable and I;m concerned that it could topple over if I'm not careful.
I have tried fitting a side stand extender purchased from Nippy Normans but this catches on the main stand and, as such, won't raise the side stand fully. If I put the side stand up first then the centre stand won't raise up fully as it catches on the extender.
Would it be possible to fit an adventurer side stand and/or centre stand to overcome this problem. Are the side and centre stand fittings the same on both 1100 and 1150 adv?
