Steven1901
Hello all, I am a newbie to the forum so hope this post is in the correct place, and thanks for having me.
I have just bought a r100s 1978, I am wanting to fit a Siebenrock asymmetric camshaft, my engine has the long nose cam with points and, if I'm not mistaken, Siebenrock only make the cam for the later canister ignition type cam. My idea is to fit this cam as I like the extra torque. I am aware that the oil pump will need changing, new timing gears, chain and tensioner, timing cover replacement and I will fit aftermarket electronic ignition. Is there any reason this can't be done, is the crankshaft the same on both engines? are the valve sizes the same? everything is standard including valves which I plan to have replaced with unleaded friendly ones any views and ideas would be much appreciated, thanks in advance, steve
