HELP,i've fitted indicator's from my ktm to the GS,on the hazard setting thay work perfectly but on normal use thay flash fast like a bulb has gone,i've been told to run another bulb(under the seat or wherever) to cure this..any idea's.....loz
Check the bulbs are 21w. When I fitted Touratech mini indicators, they came with a different wattage (can't remember what). Just fit the bulbs from the BMW indicators you took off & that should solve your snag.
Glad you're enjoying it - if the indicators you've fitted are the same ones fitted to Ducatis, Triumphs etc, then the large BMW bulbs will fit without any drama - give them a try - I even managed to cram Malky's WideTails into the rear ones...
These people can supply the same indicators that CCM fit to their stuff......cost.....£8.95 a pair with bulbs that don't need swapping.
Triumph wanted £52 for the same type of spec (that is flexible).
They asked me if I wanted anything else, so I said "qoute me happy" after a discussion I got a Scottoiler and dual injector with the indicators and postage thrown in for nowt....result or what!
