2006 1200 gsa 55k
Noticed a small leak from final drive housing ( appeared to be coming from behind large plastic cover, suspect faulty seal)
Purchased new seal from dealer.
Prior to replacing remembered reading somewhere that hot weather could cause weeping from seal. So prior to replacing seal decided to drain and renew fd fluid. What came out was dark brown, no evidence of metal on speed sensor or drain bolt, good start. No play in rear wheel. 220ml came out. 180 ml put back. 40 miles later, no leak. Happy teddy. Would appear that spell of hot weather must have had some impact on seal together with the 220ml.
Recently spoke with previous owner who explained that he had the original fd upgraded, something to do with the failing bronze bearing on early models.
Thought I would share this experience for what its worth.
Only issue with her now is an annoying small oil leak coming from behind the black plastic alternator belt cover, lowest fixing bolt.
Any ideas? Big/Small job?
Steve
Steve
