'Smokin' 650 ...
oblertone
Strawberry fields ... forever
Mid Devon
... Jaq's F650(800) has picked up a nasty smoking habit. It would appear that the excess from the (type specific) Scottoiler gathers on the bottom of the front sprocket cover; from where it falls neatly onto the exhaust causing the issue of small smoke signals. I don't suppose it'll do much harm but it is irritating and not a little annoying :blast
The bike is 'sidestand only' and this almost guarantees the oil droplet gathers on the inner low-point of the sprocket cover; any suggestions :nenau
Well ...
... I did consider that, but the excess will still collect, albeit in smaller quantities, won't it :nenau
make up a drip guard ?
remove the oiler and do it manually ?
there really shouldn't be too much excess.
Doesn't sound right.
Get a Touratech front sprocket guard so you can jetwash the front sprocket thus avoiding excess crud build up.
But I suspect there may be an oil leak somewhere to have oil dripping onto the exhaust. You haven't overfilled it by any chance?
Mine doesn't smoke & I leave it on the sidestand. It shouldn't drip when stationary anyway.
Answers ...
... to various points raised.
Using 'Scottoil' to fill it.
Not overfilled - Checked after a longish ride and still doing it.
Jetwash doesn't seem to be a reasonable response :nenau
Will turn it down and see what happens :thumb
Answers ...
It doesn't drip when stationary, you can just see where the build-up occurs.
Its a long time since I used a scottoiler but they used to use a vacuum to switch the supply on are they different now?
Shep
Scottoiler won't work unless engine running as it relies on a vacuum generated from the engine to " power " the unit. If the oil is dripping when the bike is stationary it must therefore either be coming from excess scottoil delivered when riding, or otherwise from an oil leak.
I remember Elvie had a similar " leak " while we were in Hungary this year. She normally runs the unit at approximately half the rate specified in the instructions, but had turned it up as she had to prime the unit because she had run out of Scottoil. ( see blog for full story ) One morning on routine checking there was a small puddle of oil under the front sprocket area. After checking oil level she decided it was due to excess Scottoil, turned the rate down, and no problems since.
If you are worried about running the Scottoiler at a lower rate than specified I would point out that we have run the units on various bikes over the past 10 years, and after finding Scottoil on a couple of rear tyres when first adjusting flow rate we settled on our current rate of one drop every 2 minutes as opposed to the recommended rate of 2 drops every minute. As yet we've not needed to change chain or sprockets on any of our bikes. Elvie's blade is on 25,000 miles or so, and the chain and sprockets are fine.
I'd also point out that all the above relates to road riding only, I suspect that offroading would require a different approach.
If you do have the original sprocket cover fitted, excess oil and crud WILL build up behind it until it starts dripping. Mine did so I got the TT cover to better keep it clean.
Otherwise, take it off and have a good clean up. :thumb2
