WD40 helps to reduce the effort in turning it out.
Any one got any ideas on how to remove a snapped off bolt? it is the one that holds the front of the plastic engine protector on.
Thanks.
Can you see any of it or has it snapped off flush ?
........... i will give it a go with the drill ,
I wish someone would make a left hand drill bit, ..
Don't worry about it - The two bolts left holding the plastic guard are enough to keep it in place.
No, it as snapped off flush, as soon as the locks and door defrost to the bike safe i will give it a go with the drill ,
Be VERY gentle with this you can pop the moulded spud off and into the case behind! then it's telelever off to and the rest of the gubbins to change the cover!just put a centre punch in it,
easy job to do it it is pain in the arse a you can get very worried and worked up over it as you think will damage engine case
I wish someone would make a left hand drill bit, dead handy to remove broken studs, try and drill it out, and when the drill snares it will prob undo the broken stud by winding it out backwards with the aid of some heat and plus gas.
Now theres a good idea..
Any ideas who makes them?thnx Paul.They do...
off to ebay we go.http://stores.ebay.co.uk/Gowler-Tools/_i.html?_nkw=left+hand&_sid=532671445
http://toolstoday.co.uk/shop.php?sec=cat&cat=1945
On machinery, I've always found the best way is normally by welding, like this http://www.markthewelder.co.uk/id69.html
although I wouldn't do it on a GS cause of all the electronics.
As an apprentice, I was told that the way WD40 works is that while you're waiting on it to penetrate, you think of a better way of doing the job. I agree with that to this day
I'd say left hand drills are a good bet. Drilling / stud extractors is a last resort, it's very difficult to drill on centre with a hand held drill. The parallel type extractors are the best, the taper ones just expand the broken bit in the hole. Remember it sheared off cause it's siezed in the casing.
I've had success with drilling then machining it out with milling type tool on a dremel then running a tap down the hole.
From memory, these bolts are m5. I'd be tempted to just leave it, it's only a cover, three bolts will be fine.
You could always silicone the head of the 4th bolt in the cover to make it look pukka, that's what they'd do if they sheared it off at the dealers anyway, isn't it...![]()
