Snapped screen adjuster knob
Baz
West Yorks
Managed to snap the screen adjuster knob yesterday. Anyone know if its fixable or is it a complete unit?
Cheers Baz
Is it likely to be covered under warranty or is brute force excluded:blast.
Think I may purchase the Cymark supports as a short term fix for now.
Depends how you describe "brute force"
I sneezed and it fell off...
I was doing pull ups on the adjuster knob....
Or somewhere in the middle?
The screen hadn't adjust to the fully up position so I applied a bit more torque. I was surprised that the mechanism is all plastic, would have expected the knob to be fitted to a metal rod.
Complete unit. I managed to snap mine off when trying to adjust it at 80mph!:blast
My dealer at the time managed to swing it under warranty, as they are a decent bunch.:beerjug:
Lots of complaints about knob coming off when driving at motorway speed and trying to adjust screen, apparently wind pressure problem, so I reckon if you forget the word forced, and just said adjusting normally, you would probably get good will.
Ill maybe have a look at the warranty route. Not had the bike long, and it wasn't from my local dealer so not sure how accommodating they might be. Might drop BMW a line.
There was a guy on one of the facebook GS groups selling an electric conversion... But that wouldn't work with any of the after-market "steadying brackets".
The Puig one as it doesn't clamp, maybe it would work with that?
Well this is the broken part, made of plastic. I might see if I can file some if the meat off the collar which may give me a bit of extra shaft to play with although it would restrict some of the movement. Anyone know how easy it would be to knock something like this up on a lathe or would 3D printing be an option?.
3D printer would do the job fine
Try to print it with carbon-fiber re-enforced material. That is way stronger than regular plastics like ABS.
Take the pins out -
And refit the broken bits
But use epoxy or similar and rejoin them
B&Q does brass tube in one of its moulding aisles - Sleeve it and fit it into the handle / drill & pin (glue) to keep in place
I ordered a second hand one. Ill save repairing it until the winter.
