Spanner size for evo brakes
Green Boy
hampshire
Hi all,
Got most of the way through changing the brake fluid the other weekend which was not difficult based on the instructions in here. Well as long as you exclude the sheared off rear bleed nipple...
Anyhow ran into a bit of a drama ref bleeding the control circuits as I couldn't find a spanner that would fit the 6 bleed nipples. Does anyone happen to know what size I need? I would guess possibly 7-8mm but not sure.
:thumb
If you cannot see what size it is, take some callipers and measure it.
Or you could try different spanners until you find the one that fits.
If you managed to shear off a bleed nipple and can't work out what spanner size to use, should you be allowed near the brakes?:rob
