Spare capacity
rovert57
WIRRAL
What’s the spare capacity for the t/c 1200gsa electrical system . Thinking of wiring a spotlight directly from the battery
The lower power alternator is something like 500 watts. Spare power is not a problem.
If you use LEDs the alternator will hardly notice.
Wire them with an ignition controlled relay so they don’t get left on by mistake.
If you have a GSA, the OEM spots "Aux Headlights" are individually fused.
Main beam is weak especially if you have a half decent LED or HID in dip beam. I wired the narrow angle spots via a relay to work only with main beam. Their power comes from one of the OEM spotlight fuses. I used to other fuse to run the LED daylights.
Alternatively, the under seat power outlet +ve can trigger a relay controlling a septa fusebox. It's canbus controlled so goes off (eventually) when you switch off ignition.
