Spare power plug on a 1250 GSA
paddy
Chichester
Anybody point out to me where this is on the GSA.
It’s the one you plug the bmw three pin into.
Em no I believe there is a spare plug. Well there was on my older Gs ‘s so I can get the splice adapter and connect my garmin radar.
My 1250 (2019) doesn't have a spare
I have a plug up by the display on the right hand side (now swapped out for USB) otherwise there isn't a second plug on the bike.
AS already mentioned you can convert the plug used by the Sat Nav to power a device
My (2019) 1250 has a spare BMW plug tucked under the right side of the fairing cowl, loomed next to the Nav 5 plug. Not sure of it’s purpose but noticed it when removing the nav assembly
Thats where my navy assembly also plugged in
You can buy a “Y” lead that plugs into the lead to the socket, connects to the socket, and leaves you a spare switched live and earth.
I got one for my garage door remote. I guess you could fit two if you needed another connection, or just hard-wire into it.
That’ll be what I’ve got then, cheers (y)
