Bighorn
can anyone let me know what spark plug spanner I need. I rang the dealer today, and they said i need two different ones for the two spark plugs on each cylinder???? but they are the same type. I'm confused!!!!
PS - Be carfull when you remove the caps as they are also the coils! Use the tool in the tool kit to remove the cap, push it to one side to hold onto the cap quite hard then pull firmly.
).I always struggle to get the caps/coils off with the special puller thing. It seems to slip off. Can anyone explain the knack that must be needed?
Halfords +1
But I haven't had to change a plug at the roadside since my GP100 days![]()
I used to have to take a plug out of my KH250 and heat it up on the gas cooker to get the bloody thing to start on cold mornings![]()
Perhaps I'm being thick, but I thought that spark plugs were designed to be the same size ie one spanner would fit all spark plugs.... To be sure take a sparkplug in with you to make sure it fits before you buy it.
Mmmm. Fair point re the total numbers sold, but the percentage of the people on this site who may go fording will rocket. I take it you haven't met Fanum and been encouraged to go on one of his rideouts.... The question is, out of the 100,000 plus models sold, what proportion of them wil be fording rivers etc.?
There must be a knack to it Robin, as I can't get the plastic thing to work either. When my spark plugs needed taking out after a fording "incident" I'm pretty sure they just prised them off with a blunt screwdriver.I always struggle to get the caps/coils off with the special puller thing. It seems to slip off. Can anyone explain the knack that must be needed?
Tools with government arrows in the garage, tut tut old chap.
