Speed Cams
Redboots
Member well-known
Deep in the Vosges du Nord
I use Kurviger and it does not have a speed cam database. Addons like CamSam don't work with Android Auto.
So... I downloaded a fixed cam, Garmin format, .csv (rather than a .gpx) from SCDB, with the appropriate .bmp for an image.
Then I ran it through POILoader to get a .gpi file, selecting only France Germany and Lux to keep the file size down.
Then, I ran it through GPSBabel to convert it to a .gpx file - the reason for this is Kurviger will not use a .gpi
The resulting .gpx can be loaded into Kurviger as an Overlay. Yea!
Not perfect as the .bmp image seems to get lost in the conversion and I just have a red dot.
The name is also not so good - like [18762]-@80 for the camera near Niederbronn.
The @80 is the key as its the speed limit.
I will see how it works en-route to Haguenau tomorrow and then see if its worth playing further.
I got it to work, sort of.
There are too many fixed cams to have all Europe so split them into countries and that makes the file_size small enough.
The overlays only seem to work when navigating and they are not announced.
More tests required.
Can't you just look carefully at your surroundings and drive slower? :cool: :cool:
