i'm new to this guys so be gentle! had the r1150gs for 18months now and since fitting sat. nav. i've noticed that the speedo reads 10% over. someone has suggested that fitting a different front wheel hub drive (from another bm model) cures the problem but they wern't sure which model it was from (the gs one has a 3 printed on it and they seem to think that the one to cure it has 2.87 on - this is the gear ratio i pressume) any thoughts will be appreciated
many thanks, sherpa
I fitted the drive from a R1100R to my Adventure, this briought the inaccuracy down from 10% to about 2-3%, which I'm content with. There is a corresponding reduction in the distance recorded on the odometer.
MikeO
ps I used the GPS to cross check indicated speed / actual speed. The new drive cost about £25, I got mine from Sherlock's. Dead easy to fit.....
The only reason for the difference between the indicated and actual speed is due to the fact that to be accurate the front wheel needs to be in contact with the ground.
GPS are good d at measuring altitude and forward motion not necessarily requiring ground contact
wow!! what a response - many thanks to all
i'm on my way to the dealers in the a.m.
and it will be fitted in time for tea!! in reply
to my old pal swooper - at least my gs goes
where i point the front wheel - whether it
be tarmac or not!
thanks again to all who helped
keep between the hedges
sherpa
be tarmac or not!
sherpa
