Deleted account 211025001
- Joined
- Feb 3, 2005
- Messages
- 8
- Reaction score
- 10
I think the reply was a complement instead of the usual slagging off that is often dished out.
Ah yeah, I think you're right
Andres
. I use a little compressor with a guage. I too measure in psi at that point
Ok. You got me. I do exactly the same. I use a little compressor with a guage. I too measure in psi at that point
Hi all.
Having picked up our new 1250 GS Adventure TE about 3 weeks ago I am loving every mile I can put under the wheels.
All is rosy as they say, but I have noticed a large (well, I think it is large) inaccuracy with the tyre pressure sensor readings. I have a Venhill pressure gauge that was check for accuracy about four months ago and it under-reads by about 0.1bar, so 2.9bar will show as 2.8bar on the dial. I also have two other gauges that are reasonable accurate, but not checked.
On the new GS, what I know to be a correct 2.9bar when the rear tyre is cold, shows up as 3.3bar on the bike. The front shows 2.9bar on the display when I know is is 2.5bar.
I've been rinding for long enough to be able to make a call on what feels right on the bike and adjust pressures accordingly, but is this level of inaccuracy of the GS pressure monitors normal?
I would add that I also have a K1200 R Sport and the bike pressure gauges typically over-read by about 0.1-0.2 bar max.
Grateful for your thoughts.
Many thanks, Simon
Ah yes agreed, I meant when setting pressures using a gauge. I find it a lot easier to set to, say, 42 psi than I do 2.9 Bar.
Andres
Hi SimOv
The tyre presure sensor will not always show actual pressures, rather it shows compensated readings for an ambient temp of around 20 degrees C.
Here's a link to an old thread on ADV. https://advrider.com/f/threads/rdc-...s-actual-number-of-sensors-supported.1151421/
Enjoy your new bike!![]()
I read that far into the manual - actually, I read the whole thing. But I never quite grasped how and in what way it would 'adjust/compensate' for temp changes. Of course, I understand now, but that came from using it!Can. Worms. Open.
Seriously, many thanks for all the input, suggestions and links. On page 165 (does anyone actually read this far?) of the owner's manual I have discovered it does explain some of the thinking behind the 20 degrees ambient temperature. However, the average temperature in Aberdeenshire is 13.5 degrees, so I may need to buy a new calculator.
The bike goes in for its first service next week so I'll take the opportunity to quiz the guys there about what still feels like a significant discrepancy, particularly if other 1250 owners are experiencing the same thing...and the TPMS variation on my K12 is minimal.
In the interim, I'll keep using the Venhill gauge.
Simon
). I checked the tyre pressures on the dash and sure enough, it showed them to be down by about 1-1.5 bar. Yes, as I descended and the temps rose, so did the displayed pressures.You're right. I'm doing a half mental conversion and messing it up.Do you actually mean Bar? or PSI? 1 - 1.5 bar would be way too much difference. The rule of thumb is 10 deg C = 0.1 bar (about 1.5 psi)
The rear I run at an indicated 3.0 bar. That's what it read the whole trip. Up on top of the pass, it reduced to an indicated 2.7 bar, which was noticeable to the ride - lots of luggage and lots of twisties so easy to feel the change.
Yes. Putting a little more in would be easy too as I have a compressor and guage (Thant makes sense. In that situation, now you know about it, before going up I'd add 0.2 bar (3psi) to compensate. I'd rather have it high than low with weight on board. Then when you get down again, it's easy to let some back out. Under normal load, 3psi wouldn't make a great deal of difference over a short time, the tyre would be warmer than the ambient temperature anyway.
).Thant makes sense. In that situation, now you know about it, before going up I'd add 0.2 bar (3psi) to compensate. I'd rather have it high than low with weight on board. Then when you get down again, it's easy to let some back out. Under normal load, 3psi wouldn't make a great deal of difference over a short time, the tyre would be warmer than the ambient temperature anyway.
To be honest, I probably wouldn't be arsed to change them. But it's the first time I had that experience. Now I know, I'll just be ready for it next time. I tend to have quite a bit of luggage, which will probably increases the chances of feeling any change in pressure.In all my time of going to the alps, I don’t think I’ve ever once seen anyone fiddling with their tyre pressures before ascending to the top of a pass, irrespective of the expected temperatures at the top, nor fiddling with them again on their return at the bottom.
