This is proving to be an unexpected barsteward of a job and I am not even talking about alligning the wheel !!!
The spokes are virtually welded into the rims and the bike is only 3 yrs old and non corroded for sure.
I have soaked the heads in dismantling fluid
Removed the tightening nut and central grub screw. This screw is very tiny and you wouldnt know that it was there unless someone tells you:
First I tried tapping the spokes from the top end, and as per AdvRider, this is a waste of time because the spokes are too flexible.
Then I managed a fantastic grip with mole grips, but they still wouldn't budge.
I did as per instruction, cut the spokes very short and tried to tap them out:
As I said, they are a basteward, but with great difficulty eventually moved. Trouble is that tapping, widens the tapped end and they will not tap through! AArgh !
I have got as far as the heads protruding:
but am completely unable to tap then further out!
Tomorrow morning, I will take the wheel to work and carefully cut the heads off and tap them back the other way.
Not an easy job and when I asked my dealer, he said that he couldn't remember ever having done any spoke jobs.
So new spokes arrive tomorrow and hopefully it'll be back together again.
If you are out in Kazakhstan, and you damage a spoke, just leave it there because no way will you get it out, trust me !
Now, does anyone know what the grub screw does, because I am unable to understand it's function?
