stainless bolts for front engine cover
wreck diver
worcestershire
Hi,I am looking to replace the front engine cover allen bolts on my 1150 with stainless ones,are they all the same length? What torque do they need to be tightened up to?
Anyone know what size they are to save me removeing one as a pattern.
thanks.
Installing alternator mount cover
• Place assembly sleeve, BMW No. 11 5 680, on
crankshaft.
• Clean and de-grease sealing face (arrow) and
apply 3-Bond 1209.
• Install alternator mount cover.
X Tightening torque:
M 8 screw .................................................... 20 Nm
M 6 screw ...................................................... 9 Nm
tried to copy/paste the image but I am not that good wiv computers
If i remember rightly....
4 screws for the black plastic cover.
2 types of screw for the alloy cover.
2 of one size and about 12 of another.Its best to check yourself.
I found the rigid oil pipe to the cooler gets in the way,so i changed my screws at an oil change when i could remove the pipe from the sump end.
