starter motor rebuild in manchester area
Take yours into a local trade motor factors and see if they can get you one. Twas what I did and paid about £80 for a new one.
have you tried the local auto electricians? I had a bosch stsrter motor rebuilt for an old airhead, was only about £20, albeit four years ago.
had mine done in Blackburn, if you dont find one nearer let me know and I will find details for you.
B
Try GE Middleton, City Rd Manchester.
0161 872 0923/8409
need some more help please, middleton replied nowt wrong with starter works fine, already fitted a new battrey, so its not the starter or battrey, can anyone point me in the direction to look at next please? already checked the earth and thats good, and as far as I can tell all wiring is intact :nenau
A quick and barbaric test of your starter and battery is to short the big {13mm) live starter terminal to the solenoid (small spade) terminal on your starter motor using an old screwdriver, there may be a spark and the starter should crank, if it does then its multimeter time to find the fault. or ride around carrying an old screwdriver.
Stewart
With the starter off and bench tested (buy me and local starter/alternator shop, as above but jump leads direct) it worked no probs everytime, but on the bike it would work 1 in 10 so I stripped it and found the magnets loose.
Direct 12volts with no resistance on the starter no probs, loosing some volts and resistance of 2 dustbin pistons worth of compression, problems..
