Starting on One Cylinder
needlongerlegs
Felixstowe, Suffolk, UK
Hi Peeps,
I've got a 1991 R100 thats giving me grief,
Starting from Cold it always fires up on one cylinder,
After a few seconds the second pot chimes in,
I've rebuilt carbs, checked chokes ect,
Repaced plugs and checked all connections,
An I missing something :blast
Hellllp NNL
have you tried a kettle of boiling water over the carb on the side its slow firing up on :augie
Yes and it works every time, problem is finding a kettle of boiling water if I stop somewhere away from home :D
I rebuilt my carbs recently with all o-rings/diaphrams and made sure every single hole is open. Then made sure the choke assembly is the right way around.
It now starts easier and on both cylinders.
Maverick, would you say it's fixed it or just 'easier' but still a worry to start?
NLL, have you made any further progress, as my R100 is doing the same. The l/h pot won't fire up without a struggle.
Timpo.
Nope, Getting Depressed now,
I'm about to set fire to it,
Carbs Cleaned again and rebuilt all new jets, and diaphrams etc,
Have check choke function by lifting arms both cylinder stall about the same if chokes are lifted
New Plugs and Leads, I removed coil cleaned it up all looks good,
Bloody thing still starts on one and then second one chimes in,
Could it be coil?
Needlongerlegs
Forum User
Country of Residence: England
Private messageE-mail needlongerlegs
re Starting on one cylinder
Ive just had tis same problem with my 1991 R100GS.
I did loads of stuff to try and sort this problem, but the thing that sorted it was to replace the choke disks with "old type disks" as they have four holes in them whereas the newer type disks such as the ones that I suspect you have on your bike only have two holes, so it stands to reason that you get a more progressive choke action with the old type disks.
Hi Peeps,
Hellllp NNL
On my bike it was one of the early signs of the coil breaking down.
Defies logic, I know, as the coil fires both cylinders but once I changed the coil the starting on one cylinder and various other traits disappeared
Mine only does that when I forget to turn the petrol on - have you pulled the float bows off and checked that when you turn one tap on you get a good flow of gas at both carbs?
I am not entirely sure. I think It is something to do with the choke disks ? (or something in the cold start system) a sign of worn parts or incorrectly assembled carb. It seems to be becomming the airhead version of the displaced throttle cable outers problem that seems to occur regualy for first time tank removal from an 11XX.
My bike can be a bit slow starting on very cold mornings. both pots equally slow to fire up. this morning I tried a kettle of boiling water over both carbs and it started almost the instant I pressed the button :thumb2 so thinking my carbs could be getting a little worn so it maybe be an idea to rebuild the carbs intime for next winter. But you know what they say about assumptions :rob:D
Timpo.
Hi Timpo,
It is sorted now and fires up easy. Haven't had that sub zero conditions of December again and that would be the ultimate test. There is a little o-ring on the choke body shaft which needs to be checked as well. Mine was well knackered and think the choke did not close fully some times either hence struggling to get it idling properly when hot.
It now fires up and idles just touching 1150 rpm when nice and hot. I can set it slower but hate that bloody little red alternator light flickering :D
You know I'm thinking exactly the same, double checked everything today,
Cleaned choke circuits again, eveything looks fine,
Choke on full, hit button catch it on one gentle rev and in comes pot two dooooooooh, then all is fine, and only dos this from cold
B*****dy Thing LOL
And its the left Pot.....Timpo....
NLL
Hi Timpo,
This sounds promising... I'll be on it at the weekend.:thumb2
Thanks.
T.
Touch the exhaust headers
Yup, b****y thing is random, first couple of times it fired up on one side then couple of hours later it will be other side, pain is once its fired up once its fine, so have to leave it couple of hours before trying again, coil should be here tomorrow so we'll see, NLL
