bluebilly32
Hi all, I'd be really grateful if I might get a solution to my problem. My GS1150 has 81,000 km. I was recently having trouble with the battery holding its charge (new battery). I checked the altenator belt and adjusted it (by the book 20Nm). I also was going to adjust the valve clearances and took a look at the left hand side when I realised I'd misplaced the tool for checking the Gap. I put everything back together but the bike won't start. There is a spark from both plugs and the battery is fully charged. There is fuel in the tank and the throttle cables look to be seated fine. I've tried starting it this evening as well but no good.The engine is turning over fine. The ignition cable under the Altenator looks fine and I'm pretty sure I didn't damage it.
Any advice would be really appreciated.
Bill![Blast :blast :blast](/forums/images/smilies/doh.gif)
Bill
