scrap man
when i start my bike i have noticed that my clock resets it self back to zero any body got any ideas whats happn, is my battery on way out, cheers scrapman
The battery or its connections would be my 1st check![]()
has the gs got special batt or what
aiden ma bike has only done 11,000 miles a hope its the batt mate off to france in a couple off weeks so need to get it sorted cheers scrapman, the only thing a noticed is that when it goes to start you would think it backfires through the inlet side it pops through the filter housing??????
BTW when it finally dies then an Odyssey battery definitely won't be MY battery of choice. Not sure where you got that idea from Aidan.
The battery of choice is the original OEM GEL.(for those of us who can't bimble down to Putney)
If you read what I wrote instead of what you think I wrote you would see that I didn't recommend, nor say that I have an Odyssey
YES Thats the problem - the more often this bollox is repeated the more people will come to believe it.merely that they seem to be the battery of choice about here.
quite aware of that. me too 100 miles and involves passing into LondonPutney is a fair wee bimble from where I am.
Are you giving it some throttle when starting? if so don't, if not then![]()
Why not to give throttle on starting?....and does that include the choke / rev increase thingie?
thanks
... Do a search for TPS reset and make a pot of coffee.
ps - If your low mileage bike .
Sometimes the magnets come unstuck from inside the starter casing and will draw extra volts from the battery causing the clock reset etc.
I had this starter failure on a brand new 1150 and we have just replaced the starter on my mates 1150 after it had started to gradually let him down with the same fault.
http://www.ukgser.com/forums/showthread.php?t=197156
Scroll down that and if you need a new starter for your trip to Frogland the info is there ..........
Ps. I agree that the best battery is the standard BM Gel one. Still going strong on mine after Five years.
