Stebel Magnum horn on 1200GSA LC
2 wheel humvee
www.humvee-graphics.com
Barrybados
STEBEL Magnum horn fits the 1200 GS Adventure with little or no alterations shock..........
It fits in the same place as the original pizza bike horn, on the original bracket too, it fits in the correct orientation i.e. trumpet facing forward and......it doesn't trip up the CANBUS wiring system, of course you will need to either buy a wiring harness/connector from Nippy Norm to suit (or make your own) but it fits and it works with no other alterations, just thought I'd share that with you all :thumby:
Any horn with high current draw needs a relay so done right it shouldn't affect the Canbus
Sent from a widget that can't spell.
Nippy Norman he advertises here, get the wiring adapter from him too :thumby:
Couldn't tell you sorry, I'm away for the weekend now but will take a pic or 2 and put them on when I get back.
CHECK YOUR HORN .............. Its NOT STEBEL........... It FIAMM.......... AND if your going to post pls post the correct shit and not bullshit
Wind your neck in, it's a Stebel Magnum, it's done sterling service on 2 previous bikes and is now on this bike, next time you want info try using google your fucking self :tosser:spank:sleep
.i.
.i.
Well you should have said that DIP STICK instead of pointing to Nippy's for a product they no longer carry
Very good to know as I have a Stebel Magnum sitting at home from my old bike so good to know I only need the wiring adapter. Thanks for posting some useful information :)
OK I'm a bit of a numpty,
so do I need http://www.nippynormans.com/f650gs-08-on/horn-wiring-kit-for-bmw-bikes-with-canbus-wiring which seems to be a canbus plug and some spade connectors (for SEVENTEEN QUID !) - anyway - am I right in assuming this is to power the horn relay (not supplied) which I also need to wire in with inline fuses for both relay and horn power line ??
I have used Nippy Norman's wiring/connector but have not fitted a relay, no issues at all to report.
