I always use a proder device, (a point in the tip with a fuse that lights up, a wire out of the top with a crock clip on the end, to earth) tec name a circuit tester, then I know if there is power there or not, I am no expert so I go through all the live wire's in order after that I would check that you have the right wire from the horn button conected.
Hope this helps.
