STEBEL NAUTILUS INSTALL ON 05 1200
BlueBird
South Wales
had a look at all the other installs and thought I could do better and decided that mine was gona be as unobtrusive as possible.
I got it mounted in one piece just below where the orginal horn sits,
indeed it it possible to leave the orginal in place if you make the bracket a little longer.its a very tight fit,particularly where the wires sit either side of the brake pipe union,again if you made the bracket longer it is possible to miss this but you may have cables and clutch pipe rubbing on the nautilus if it lower.
where it is now it misses everything.
The relay is mounted under the tank screwed to the plastic holder of the various black boxs.
The bracket is 5 mm thick, 28mm between hole centres,16mm wide spacer all in ali,
