pink panther
I've replaced the clutch hose and brake hoses on my 1150 gs,no problems so far.The bike has been lying up for a week or so while waiting for a hollow bolt that connects the hydraulic clutch hose to the slave cylinder. My intentions today were to refill the clutch master cylinder with clutch fluid and bleed the system, other than that it hasn't been touched.The problem is the fluid will not leave the master cylinder to fill the system when I pump the lever, there is no pressure at all,I loosened the hose at the master cylinder and pumped the lever forever and a day but the fluid level is still the same. By the way the clutch lever is now making a noise similar to chewing a balloon.
