Please, I am now struggling for a solution -on my Purple 100GS PD -1994.
Not made it to the Belgium Rally 'cos my Turquoise PD has a missing main bearing locator pin, and is with Mr Scriminger.
So, was planning on using my Purple PD , but oh no ....it's running like a kangaroo- very jerky on falling throttle below 4K revs; runs a treat above 4K.
So far -
checked timing -good
checked compression -good to excellent
replaced spark plugs, plug caps and HT leads
replaced carb diaphragms
squirted copious amounts of carb cleaner into carbs with engine running
Balanced carbs as best I could
Still running rough and jumpy.
However, one clue seems to be that plugs are really sooty/dry black, but this might be due to having to run at idle speed into road to my lock up ?
I am now going to check mixture settings again, and clean out the pilot jet with more cleaner.
Any suggestions please, as timing is fine, so unlikely to be bean can or hal sensor, and compression is good, so unlikely to be burnt exhaust valves, and bike runs great at higher speeds.
Two possibles though, as I am unsure as to what symptoms of a faulty Ignition Control Unit might be, and secondly, my bike still has the secondary air circulation system fitted, which I want to remove, but can't find a suitable "blanking - off" cap for the threaded outlet under the exhaust front pipes (16mm - 1.5 mm pitch ?).
So, sorry not to join with the guys in Belgium, and no Belgian beers for me then
So far -
