Stoping a route / turning the XT off
jfheath
Yorkshire
Turning off the Zumo
A. If you stop a route by pressing stop 'X', the route has to be reloaded and restarted as a brand new route. We knew that already.
B. If you stop a route by pressing the power button on the back of the machine. The route will restart from where you left it. (I don't know about moving elsewhere while it is in this sleep mode).
C. If you stop a route by holding down the power button for a few seconds until the red Turn Off button appears, then when power is restored, obviously the satnav knows where YOU are, but cannot relate this to your position in the route, which is no longer loaded in active memory. This last point is different from the way that the 590 and 595 behaved after a cold start.
