Struggling with recent notchy gear changes when using clutch 2022 r1250gs
freddy871
Uk
Hi all , need some advice for those in the know.
I have a 2022 1250gs with 37,000 miles on the clock . Over the last 3-4 months i have noticed that what was a buttery smooth gears i am now feeling a notch when changing up and down the box. Sometimes i get a nice change but more bad than good these days sometime a mis gear or even a crunch.
So far have checked the gear linkage for stiction and also check for clutch drag and slippage . all are fine from what i can see.
Thought maybe linked to gear assist pro so did transmission and assist relearn . still no change .
Would say bike is slightly better when stone cold.
Not sure where to go next or what to check , and if honest dont want to do the dealer route unless i can help it. Any tip advise would be greatly appreciated .Or worst case anyone know of a good BMW tech in Essex/south of England area could be a last resort.
Thx in advance J,
Alternately, try Paul at MotoDP, Rayleigh - BMW approved and has a reputation second to none locally - you can reach Paul on 07738 161707
UPDATE !!! Clutch fluid change and bled. Engine oil and filter change. Gear linkage cleaned and lubricated. Transmission adaptations reset and re-learned with Motoscan. No clutch slip, although a small amount of clutch drag when on stand and i hit 1st gear . Can stop wheel from spinning with a little force. I am thinking new clutch next as run out of ideas and cant think of any other routes . Unless anyone out there can offer new information
Have you ridden it? Still poor shifting?
Yep ride to work today , I think oil change made a tiny improvement . But still getting poor shifts where it feels like clutch is not engaging correctly , especially going up the box . Down is better ..
Thx in advance J,
BMW dealers replace the shaft drive unit on 1200 and 1250 water boxers for free every 36,000 miles. Its claimed to be merely a precaution, but it could easily be where the roughness comes from.
NB on the 1300 models this is chargeable to the customer!
Hey RS shaft already replaced last December , so happy that's not the issue . 👍
It does seem to coincide to when the shaft was changed though, 3-4 months ago? I'm clutching at straws really, I can't see how a supposedly new shaft could cause an issue, can't really install one wrong as far as I know but, it does seem a coincidence.
