Sump plug
Doc
Ey Up
Slawit
Removed sump plug ready for a oil change and found remnants of PVA tape on thread.
Thread looks ok though so why have they used this 🤔
Question is should I buy a new plug use pva again or put back in with new o ring and keep an eye on it ?
Cheers Doc
Oh fook!
Not nice.
Repack with tape and carefully replace.
If it leaks you could resort to running the correct size tap through it to try to re-establish the thread, same with a die on the plug.
Failing that, an insert
I would buy a new sump plug and washer.
Try it, if not oil tight helicoil the sump thread
I think someone has not changed the o-ring seal at last oil change and just used some PT tape to be on the safe side.
If it was me, i would just change the o-ring seal and reuse the sump plug.
I agree. Or perhaps someone gorilla-d it, tore the o ring and then added the ptfe to stop the leak. I’d try the standard set up and see how it goes.
Never seen an o ring on a sump plug, they usually have a crush washer
Don’t know anything about Harleys but is that normal?
Same here; it's always been a crush washer for every engine i've done an oil change on in 50yrs; saying that; i've never done owt with a Harley.
Shouldn't need PTFE tape if the O ring is doing what it should. But, check the surface on the sump where the O ring contacts, just make sure its clean and smooth.
  • Like
Reactions: Doc
i have ptfe tape in my toolbox , i use it for airline fittings , if you are putting it on drain bolts there is something wrong
OR
belt , new o ring
braces , correct torque
bit of string, ptfe tape
b,b,b of s = 3 means of fixing anything , if it still goes wrong , it's not as if you didn't try.....then you don't beat yourself up if it still goes wrong.
  • Like
Reactions: Doc
Out of interest why do you get a range of torque settings to work to ?
Like 10-15 lbs why not just one figure 15 lbs.
Just aim for the middle, don't know why they do that....possibly to allow for badly calibrated torque wrenches?? :nenau :nenau
  • Like
Reactions: Doc
Thread on plug look fine. Check thread on sump. If looking good just do whatever you do JJH
  • Like
Reactions: Doc
If it does have an o ring, lubricate it (I'd use a tiny smear of red rubber grease, on the o ring not the thread) before tightening the sump plug so that it doesn't catch and bunch up between the sump and plug.
