(RIP) Bin Ridin
Hi,
I have bought a T500 same as one I owned back in 1973... and found left head gasket leaking. The 4 x 8mm screws had been overtightened and now I have oversize inserts in the barrel. Mechanically, this will be ok, as long as I tighten the 8mm screws to 14.4 lb ft and not to 25 lb ft which is for the 4 x 10mm sleeve nuts.
The barrel and head sealing surfaces are in very good nick and the head is not warped. The cylinder liner top land is slightly proud of the barrel, so well set for a good seal.
The bolt spacing on the old gasket shows some wishful thinking in Suzuki-land back in the day - anyhow, my question is should I put the least smear of shellac on the new aluminium head gasket?
