Suzuki v strom 800DE 2023 3296 miles veriden cruise control
peelrt1200
Member
lincoln
Suzuki V Strom 800 DE 3296 miles set up for the road, never been off road or ridden in the winter currently sorned. Comes with new veriden cruise control ie push button, quick shifter std, new barkbusters, cobra chain oiler, bike currently running tubeless tyres Continental trail attack 3s can be put back to std, new TPMS system, new SW Motech footrest, new Givi SR3125 + M5 plate Monokey and new Givi Airflow adjustable screen. Still warranty UK bike in vgc £7995.00
Fabulous bike !!
The best parallel twin on the market . Just spent 5 days on one Gran Canaria . It just needed cruise which you’ve fitted . GLWS
Agreed Arsey tried the Honda transalp not for me, power to high up the rev range this is a lot better and 60 + mpg all the time.
Fabulous bike !!
Did you do the Canary Motorcycles trip ? 👍
Yes.
All the guides there rave about the DE.
I rode the Transalp there in Dec 2023 and it was always in between 2nd and 3rd gear and basically a PITA.
Riding the same roads on the DE, you could generally leave it in 3rd.
Utterly brilliant bikes.
I will be getting one in the future but timing not right for this beauty.
We were there a couple of weeks ago, great roads & good set up.
The Suzuki was getting some good comments.
Yes.
If you learnt how to ride and use a gearbox properly, you'd be reet 🥱
Sorry forgot to mention the bike comes with all the std parts and all paperwork in my name.
how do the tubeless tyres work with the spokes wheels?
Rim tape did not work slight leak, used ct1 silicon and it has not lost 1 psi since being done. PS the rims are set up for tubeless tyres front and back believe it or not.
so you glued rim tape onto the rims?
I think when he says glued the rim tape to the rim's he probably means he's used 3M tape or similar to seal the spokes from letting air pass out of the rim, quite a common mod .Well I hope that's what he means :unsure:.
