Swing Arm Bearings
colint
West Yorks
The swing arm bearings used on the para swing arm are very expensive anyone tried using the older model set up ie taper rollers and a seperate oil seal these are a standard bearing and seal available from any bearing supplier the dimesions are the same.
They'll fit straight in. Just remember to fit the spacers between the bearings and the seals.
