Switch off headlight on GS/GSA canbus
rob mac
Gloucester
Don't mean to teach anyone to suck eggs but I only just found this out -
to turn your headlight off:
1, start engine
2, press and hold indicator cancel for 6 seconds
3, press and hold right indicator switch for 6 seconds
to turn back on
either ignition on and back on or flick dip main switch
didn't know that, thanks for sharing,
will come in handy warming up bike in the dark befrore the missus goes to work on hers,
& in an emergency it's easier to turn the hazards on pressing both indicators with your thumbs.
:thumb2
That works on my 2005 GS and on my old 2006 K1200S, but on my 2008 K1200S it will switch the headlight off but as soon as you put it in gear the headlight will switch back on again. I wonder if it is the same on the 2008 GS/GSA?
The same switch sequence works with just the ignition on (so before starting engine).
Worth knowing if you have a borderline battery :augie and are having trouble starting the bike ;)
? How do you get the lights to come on before starting the engine?:nenau
With the ignition on and engine NOT started, only front pilot light and rear light are on.
AFAIK these can not be turned off.:confused:
I can flash main beam or turn main beam on but have NO dip beam untill engine is started.:thumb2
What I meant was you can disable them without starting the engine.
So, follow the proceedure, start the bike, and the lights don't come on even when the engine is running.
Similar threads
Replies
17
Views
3,188
