Dale
Has anyone else found the System 5 to be noiser than the System 4 helmet? It is reasonably quiet with all the vents closed, but as soon as I open the chin vent, the wind noise (at anything > 90kph) is unbearable (LOTS noiser than the System4). Have tried playing with the settings on the top and rear vents - all to no avail.
Also, at higher speeds (>140kph) the front vent seems to "leak" air, also causing the noise. If I tape over the front vent, the noise goes away. Have tried it with both the standard and MRA windscreens, so pretty sure it's not screen realted.
Is this a common problem? Do I take it back to the Dealer?
